ignition trouble ?
slamer12
Help i was checking the gas gauge with my meter today and i must have shoeted out something and lost all my gauges and the ignition nothing happpens now when i turn the key im getting 12v to the panel but i have no juice the acc panel everthing works but no gauges or ignition not even power tilt/trim works i checked the fuses and they looked good the manual says there is a main circuit breaker any ideas where this is located please help ??
Boatin Bob
Re: ignition trouble ?
Is this an outboard or I/O. If I/O you may have tripped the 50 amp breaker, if it's an outboard I suspect you've tripped something under the cowling either a breaker or a fuse.
slamer12
it's an outboard i think we might have blown a fuse or two .
vipzach
If it is an I/O, the main breaker is usually in the engine area. It is usually a push button, that is red and should be easy to see. Good Luck!
slamer12
where would i be able to locate this breaker ?
vipzach
Soory did see your reply that it is an outboard, slow on the trigger today. I guess
