ignition switch
davpierc
I need to buy a new ignition switch for a 1988 Bayliner Capri. Where do I find one that will work ? Also would like to buy new on/off switches for this boat, what will work?
Thanks
David
beckspop
Re: ignition switch
Well, there is of course there's iboats own store, then you might try www.greatlakesskipper.com they have all kinds of OEM stuff as well as aftermarket parts. Good hunting....
P.s. if you scroll to the bottom of our little website there is a page just for Bayliners.
Bigprairie1
Re: ignition switch
Easy....Ebay. Search under Force and/or Bayliner.
Good Luck
BP:cool:
NYBo
Re: ignition switch
I found accessory switches that are exact fits at AutoZone.
Any ignition switch designed for the type of motor you have will work. Can I assume you have an outboard since you posted this in the Force section? If so, you'll ant one with the push-to-choke feature, like this one.
