vox populi
- Dec 11, 2024
- 3
1992 aries. original factory ignition switch key broke, got a exact duplicate. wired it up from the pictures i took, no power to the switch at all, can not find any fuses along the wiring i can see . it goes into a 97 johnson venom. looking at switch from back top left magneto, center choke top right ignition middle right solenoid, bottom has 3 ground wires M, bottom left trim not power. that is the way it was hooked up. i know the battery goes to where the trim wire is. so i ran another hot and hooked it up b post and left the trim hooked to it. everything works now except some accessories like temp/ battery gauge, dash items work without switch when master switch is on it never stopped working. my question is was the trim sending power to the switch and not now ? is the trim in the correct location ? i would think so since you need it to raise the motor with switch off. tried old switch again, did not work, possible i might have stretched or broke a wire, motor will start and turn off. just want to make sure iv got it wired correct, i can change wiring on temp/battery gauge if i do have it wired correct
