Ignition switch for a 1995 Cajun Bassboat
ppare2293
My son lost the Ignition key for his 1995 Cajun Bassboat today. He did not have a spare. What is the best / quickest fix. Is a new switch readily available. He has chemotherapy on Wednesday and I'd like to get him on the ewater before then. since the marinas here are all closed on the 4th, I'm looking got guidance
cr2k
Re: Ignition switch for a 1995 Cajun Bassboat
Is it an OB or IO? If it's an OB you will need an outboard switch that has the push to choke feature. If it's an IO any ign sw will work.
5150abf
NAPA, they have alot of marine stuff and should be able to set you up.
