Re: ignition switch 94 chevy
Ignition switch as Ken says is on lower column<br />removal of switch<br />take off dash cover below column<br />loosen column support nuts a couple off turns 11/16 or 15mm<br />feel on top of column for gear pointer [wire clip] and take off column marking position<br />now continue to loosen c/bracket nuts fully<br />you can see the switch on top off column now<br />remove attachment screw or screws pull out linkage note which hole in switch it's in unplug from harness<br />install new switch to harness put linkage in and tighten screw to column, slide so linkage is snug finish tightening<br />push column up to bracket studs ,put nuts on loose clip pointerwire back on column on same position as marked tighten everything up <br />dash piece back on
