Re: Ignition Question
I have spoken to the marina that has serviced the boat since it was new and they told me the alarm will sound for 1 of 4 reasons.
1) high Engine Temp
2) Faulty Alarm
3) excessive vacuum on fuel line
4) low reservoir for oil
I have determined that it is not 1 and 2. I disconnected the tan wires and it still sounded the alarm. Also I am fairly confident that its not the engine temp because it happens immediately when started, the engine hasn't had enough time to heat up.
When i bought the boat, the person i got it from had two of the same Bajas with the same engine on them. One of them had an oil tank, the other one did not. So it looked like at some point it had been removed from that boat. I bought the boat with the oil tank, but was told i should still mix the gas. The boat came straight from the marina, where it was winterized, and there seems to be oil in the tank. Which, to me means that they are the ones who put the oil in there.
I was told that i need to mix gas and oil on the boat, but since there is an oil tank i am very confused. I am trying to get the service records for the boat to find out if the oil tank has been disabled or it is still functioning. There is blatantly a line going from the tank to the engine. In any event, if the alarm is sounding because of an oil problem, i am guessing that it thinks the reservoir is low, but since i mixed the oil and gas, the engine still runs fine. I have never primed the oil before starting the boat since i was mixing it. My guess is this is why the alarm is going off.
Thoughts??
