ignition problems with colorcoding
sweetnsassy_29511
I have a 1990 Sunbird boat with a 1990 90hp Johnson Motor. I am trying to install a new ignition key switch push choke. I need the color codes. I no longer have my manual. Any help will be greatly appreciated.
Dhadley
Re: ignition problems with colorcoding
The terminals are marked on the switch. Just change one wire at a time. Or you can order a service manual and the wiring diagram will be in there. Don't forget to disconnect the battery before you start.
sweetnsassy_29511
thanks Dhadley for the info, we finally got it wired. thanks again for your help.
