I have an ignition problem with my 45 HP Chrysler (Model # 457HD, S/N 1960. I think it is a 1972 model).
The spark plug for the lower cylinder if firing just fine. The upper spark plug is not. I am sure that both coils are working just fine. I used an ohmmeter to check them out (both were okay) and I even swapped them. Either coil works fine in the lower cylinder.
I have a wiring diagram for this motor and the ignition system seems pretty simple. It has the Battery Type ignition with breaker points.
I?m assuming that the issue is caused by the point or condenser. Is there a way to verify this before I attempt to pull the flywheel off? Even if I pull the flywheel off, what would I be inspecting for?
I attached a lead from my ohmmeter to ground and the other to the negative on the coil. I then rotated the flywheel by hand and observed the readings. The points opened and closed as I turned the wheel (Since I saw the readings changing on the ohmmeter, I don?t think there is a short).
Has anyone else had this condition? Any help would be appreciated.
Thanks!!!!!
Does anyone know of a good website that sells parts for such an old motor?
Thanks!!!!!
