ignition module
wkbullocknluv
I have a 94 sea rayder jet boat by sea ray. It has 3 cylinders and it is 90hp by merc.I know it needs a ignition module so does anyone know about how much they run and a good place to find one.
Jeff Walkowiak
Re: ignition module
have napa auto parts look one up in their small engine parts book , but be sure to replace the rectifier since that is what blows the brain when it goes bad,, if you don't replace it , the first time you shut off the engine it will kill the brain again, I can explain why it happens and even with the new style stator it will still do it but then slick will probably argue with me and I really don't have time for that, so you will just have to trust me on that.
kend301
Re: ignition module
CDI makes an outstanding switchbox CDI part number 114-4953
