Ignition Mission 2002 VP 5.7 gx
Garbj0
We recently have experienced intermittent starting with our 2002 5.7 gx. I can jump the starter from positive cable to solenoid and it starts perfect. Replaced the ignition switch and started perfectly... idled down to get fuel , stopped motor and it would not start. In the on position all accessories work, just no signal to the starter to start the engine. If you wait long enough hours/days... it starts like normal, but after idling around for as little as 2 minutes or as long as two hours, when you stop , it won’t start. Batteries, ignition switch, alternator, fuel pump all new... is this an ignition module issue? Help?
Ayuh,..... Welcome Aboard,...... Probably corroded wirin' ends,.....
Start with the battery cables,..... Every connection should be shiny metal Clean,.......
Both ends, of All the wires involved,..... The Ground points must also be shiny metal Clean,.....
muc
"Retired" Association of Marine Technicians...
Might want to test the starter slave solenoid when the problem is occurring.
