Ignition help.
10Rams
Hello, I have a 1986 mercury 75 4 cylinder. It has been sitting awhile but I replaced the trigger with a CDI trigger one wire was missing insulation. And I replaced the stator with a sierra as it had missing insulation on both yellow wires. Everything was fine as I had check to make sure the timing was correct on the muffs. Upon taking it out for the first time I had very little power. Checked plugs and the top 2 cylinders are not firing. Trigger resistance checks out fine. I swapped trigger wires and the problem stayed the same. I swapped stator wires and the problem stayed. What are my chances the switch box died out randomly?
10Rams
I think I have narrowed down my problem to the switch box. Mainly posting these specs for others to see and help solve a problem. Will report back when the new switch box arrives.
10Rams
Stator resistance
Resistance blue to blue white - 5950
Red to red white -141
Stator DVA test
Blue - blue white connected - 2v 95% of the time then jumps to volts 240 ish
Disconnected - constant 320v
Red - red white connected - 2v 95% of the time then jumps to 50 volt connected
Disconnected - constant 50v
Trigger resistance Disconnected
Purple to white - 887
Brown to wht/blk - 905
Purple to grnd - 0L
Brown to grnd - 0L
White to grnd - 0L
Wht/blk to grnd - 0L
Trigger DVA volts connected
Purple to white - 5.75
Brown to blk/wht - 4.7
Purple to gnd - 4
Brown to gnd - 3.5
White to gnd - 3.8
Wht/blk to gnd - 2.3
