Ignition fuse on '87 Johnson 50HP
jstromsk
The 20A ignition fuse has started blowing on our 1987 50HP Johnson. The engine cranks 3-4 seconds and then the fuse blows. Just had a piston replaced and the cylinder bored and the motor ran great for 6 weeks until this weekend. Any advice on troubleshooting would be greatly appreciated. Would corrosion in the fuseholder cause a problem?
jstromsk
Re: Ignition fuse on '87 Johnson 50HP
I don't believe there is any corrosion in the fuseholder but I'm not positive. I'll check it out a bit more.
