ignition fuse keeps blowing
  • not sure what this is
    Votes: 0 0.0%
  • or this sorry
    Votes: 0 0.0%
  • Total voters
lizf
1986 searay seville.
Was out on the water. Boat died. Figured out it was a blown ignition fuse that also melted the fuse holder. Replaced fuse holder and now every time we put a new fuse in. It blows right a way. Prior to even putting the key in. Any ideas on what the issue could b. Any help will be greatly appreciated. Thanks
NYBo
Welcome to iboats!:welcome:
You have a dead short between the ignition feed wire and battery negative somewhere. Start at the engine. Check for frayed wires that are contacting the engine.
lizf
Ok thank you for the welcoming and the response...:)
lizf
Can not see any frayed wiring or damaged wiring anywhere
