Ignition fuse 15A problem Mercruiser 3.0L
bob101101
I have a problem whit the ignition fuse of my Bayliner 185 2007. The fuse blowed each time that I run the boat approx 1 hour and when I change drive to neutral. If someone can help It will be appreciated.
Thank you
Sorry for my poor english I am from Quebec province.
camalot
Re: Ignition fuse 15A problem Mercruiser 3.0L
Your going to have to do some digging in the wiring loom. The cable which is coursing the problem is purple in color. This cable is your field power for your ignition, it,s not uncommon for it to get chaffed/pinched and short. This purple cable also goes to the shift interrupter switch.
Bt Doctur
camalot`s post translated
Votre va faire quelques creuser dans le faisceau de c?blage. Le c?ble qui est situ?s dans la zone du probl?me est violet en couleur. Ce c?ble est votre pouvoir de champ pour votre allumage, il, s pas rare pour qu'il se chaffed et pinc? et court. Ce c?ble violet va aussi ? l'interrupteur interrupteur de d?calage.
camalot
Sorry didn't even think to translate it:redface:
