eavega
- Apr 29, 2008
- 1,377
Hello folks. I am trying to correctly diagnose a loss of spark on all three cylinders on my 1976 70 HP Johnson. I have three references for the various tests; OEM manual, CDI Troubleshooting guide, and Clymer manual. All three have similar but not equal thresholds for "Good" vs "Bad" with regards to resistance tests on the trigger and stator:
Clymer
Trigger "Pass" - 7.5 - 9.5 Ohms
Stator "Pass" - 555 - 705 Ohms
OEM
Trigger "Pass" - 7.5 - 9.5 Ohms +- 1
Stator "pass" - 625 Ohms +- 75.
CDI
Trigger "Pass" - 10-20 Ohms
Stator "Pass" 400-600 Ohms.
Who is right? I ask because the readings I got are spot on for what Clymer and the OEM Manual call for (I got 8.5 Ohms, 9.0 Ohms, 9.0 Ohms for the trigger circuits, 685 Ohms for the Stator), but are off on both counts for what CDI calls for. I was hoping to get some opinions as to whether the Stator and Trigger (Timer base) are still good on my motor and I should suspect the power pack.
I haven't done the DVA readings yet. I just got my DVA adapter in the mail yesterday. I'm hoping that the DVA readings will give me a definitive answer, but I was curious as to which guide I need to be paying attention to, since there is still a variation between the Clymer and CDI guides, and the OEM manual doesn't even contain the DVA tests, but rather use a "Neon Test Light".
Any advice would be greatly appreciated.
Rgds
Clymer
OEM
CDI
Rgds
