eniminiminimo4
Thread starter- Joined
- Jun 16, 2003
- 3
I found the problem to be oily residue causing the coil to ground out.I cleaned the coil(at #4cyl.) and checked the rest of the motor as soon as I found the problem.It was only a small amount of oil at the problem site(couple of drops). The motor will only run about half-speed at full throttle.Could the coil grounding out cause any other related problems?
