Never had issues with my boat until this year, thanks to these great forums I was able to fix it myself. But, working on a friends boat now and I'm stuck.
Working on an '87 3.0l Mercruiser. Started with bad gas, I have fixed that situation but the boat will not fire at all. I have read and read in these forums different things to check and try and there are so many I'm getting confused and not sure if I'm doing any of the diagnostics correctly.
Without further ado, I am attempting to establish if the boat even has any spark. I started with the coil. Key on, both terminals have battery voltage (13+), when engine cranking voltage drops to 9 on both sides of the coil. I have removed the purple wires from the + side, hooked battery directly, no change. I have also disconnected the momentary shift/kill switch wire... no change. I have put a plug into the main coil wire to the distributor, no spark at all. Is this enough to warrant replacing the coil? Have I missed a step or a test?
I have read many helpful posts in here and I have also read posts where people have the same issue and have thrown good money after bad and are still parked in the driveway. Trying to avoid that.
