Re: ign question
Last test to make sure it's the switch box.. Diconnect the wrires going to the coil while testing them. If you still get those same voltages, then it is a switchbox prob. You need to be getting around 200 volts to each coil..<br /><br />Most people don't have a peak reading adapter.. I'm glad you do, as it's essential for testing these ignition systems..<br /><br />Scott..
