1987 OMC Cobra (400)<br />I need all info i can get in removing my OMC cobra drive. Heres what my manual says , <br />1. Remove Oil stick,install lifting eye, insert lifting eye<br />2>Disconnect aft end of the tilt\trim on each side. <br />3.Remove the 6 elastic stop nuts<br />4.Support the unit<br />5.Pull the drive str8 bac & remove it from boat.<br />6.Put drive in safe place<br />7.Remove & discard the pivot housing Gasket<br />8.Clean gasket from the Pivot housing<br /> <br /><br />Dosnt the shifter cable & a few other things need to be removed before i take the drive competely off.Tis is my 1st time taking aa drive off , so i will need all the help i can get
