If I post a truck VIN #.....
NathanY
Can someone tell me what year it is and other details about it? or do it by email or what ever....
one more cast
Re: If I post a truck VIN #.....
post it with an email address and if its not too old i'll send you history report.
NathanY
1GCHV33K0MF301647<br /><br />nathanyerger@earthlink.net<br /><br />Thanks guys..
one more cast
Nate ,its a '91 chevy 30/3500 crew cab 4wd.<br /> It is against the rules for me to send you a car history report..(thats what they told me when I tried to send it.) but it has alot of miles on it and no problems found.
NathanY
Yeah that is what I found too. I am trying to find the history on it, where it came from and such. Particularly, why it is a 91 with the bodystyle of a 86.. Here is a pic of it.
watermark.php
SpinnerBait_Nut
OMC, just CC&P the report, that way your not sending it.
one more cast
Tried that SBN and when I pasted it a big warning came up. It says I can make a copy so I scanned it....Hope you don't have dial up Nate. I somehow sent them open.
TilliamWe
Banned
Nate, I am not sure of the exact years, but when Chevy changed the body style in 87, they only did it on the half tons. The 3/4 & one tons took a while to get the new sheetmetal & such. Looks like 1991 was the last year. Starting in 1992, even a "chassis/cab" had the same sheetmetal as the half ton trucks<br />Mitchell Crash Estimating decoded that VIN as a 1991 V30 Pickup 4door Crew Cab 8' bed 164" wheelbase. As happens occasionally, it couldn't decode the engine. But the engine should be a 5.7, cause the eight digit is a K.
aspeck
Can you find any of the other VIN's to make sure they match the dash one? On the doors, under the seat, on the frame, etc. There are a bunch of VIN's all over the vehicle.<br /><br />Had an 81 Grand Prix come into the shop once, only VIN said it was a 76 Sunbird. "Owner" went to jail - was stolen from the Philly area, and the VIN came from a junk yard about 10 miles from us.
TilliamWe
Banned
Nate, if you want to know axle ratios & whether it's got posi or not, look in the glove compartment for a sticker with a bunch of three character codes on it. Go to the G's and that's axle ratio & posi codes. G80 means it has posi, GU6=3.42 GT4=3.73 GT5=4.10
aspeck
TilliamWe is correct on the body style change.
NathanY
got it. Thanks OMC.<br /><br />I am trying to restore this truck, but having a problem locating parts, am having to order some parts for suburban of same year, to get ones that work because of the four door thing.
Bob_VT
Just FYI you can type in a 17 digit VIN into google which will lead you to carfax. When you get there you will get the make model and year of the vehicle. <br /><br />Try it with the VIN posted in this message.<br /><br />Bob
JB
Non-boating Tech.
TilliamWe
Banned
"am having to order some parts for suburban of same year, to get ones that work because of the four door thing."<br /><br />Good thinkin there Nate. Sheetmatal & trim stuff should be the same. But be aware that brakes, shocks, axles, and stuff like that might not be the same. Mostly cause you have a one ton truck (V30) and a Suburban at the most will be 3/4 ton. (V2500)
