Idling issues
Having idling issues with the boat and need some ideas. Boat docked and running it’s fine. Put throttle forward just a little to get boat moving it drops in rpm and try’s to cut off. If I open it up I little more it runs great. It’s only at the lower end it’s having problems.
rejesterd
Hello.
Do you know what year/make/model the engine is? If you're not sure, there's usually a little plaque or sticker on it that will show a serial number.
The suggestions will be different, depending on what type of engine it is.
