On my 78 235hp evinrude i can't seem to get the idle down. There is no idle screws on the carbs timing is set at around 8 at idle. I loosened up the cable adjusted the cold choke setting put the cable back into into the holder and turned the barrel style adjuster and it didn't make a difference maybe a 100 rpm's in neutral it idles at 1500 in gear 1000 any suggestions.
