Idle Stabilizer on 1990 Mercury
kgraham
Has anyone had their idle stabilizer go out on an 89-91 Mercury, 135-200 HP? If so, what were the sypmtoms and effects from this happening?
lakensea
Re: Idle Stabilizer on 1990 Mercury
If the stabilizer is bad, the engine will stall if the idle speed drops below about 550RPM. You check it by hooking up a timing light and pull the trigger link back so the engine idles below 550RPM. You should see the timing jump up by a few degrees and the idle speed increase.
kgraham
Has anyone ever had their plugs foul repeatedly from a having a bad idle stabilizer?
