scarbro24k
- Dec 5, 2013
- 7
The Sea Ray 160BR had a Merc 3.0L with a Mercarb and it had a min. idle, out gear on the water muffs of 1650rpm.
3.0L Mercruiser eng. sn: C460258.
Replaced the Mercarb with a Rochester 2MC and it idled at 2500rpm out of the box and out of gear on water muffs.
I managed to get the idle speed down to 1700rpm with the idle mixture screws.
There doesn't seem to be much left on the idle speed screw adjustment. Maybe 1turn or less.
So, what is the proper idle speed out of water, on water muffs and out of gear?
None of the manuals I've read have the info.
They all refer to a "in gear, in the water idle speed of 650 - 800 rpm."
I definitely do not want to shift into gear this little bugger at 1700 rpm.
I checked the boat tach against my shop tach and they match rpms for 4-cycl setting.
I am waiting on a water impeller/water box rebuild kit before continuing.
I bought the boat used and I think the unit was run a couple of times with no water because there is very little water coming
out of the prop hub and a lot out of the water tube near the universal joint.
The engine water temp stays at about 170F when warm.
I have more experience with a 1977 SeaRay 240WE OMC 235 engine than the Mercruiser. So, I'm learning.
I have the Seloc Mercruiser Sterndrive manual and several downloads from the Adults Only section
and I have watched several of the Youtube videos on the water impeller replacement, carb replacement and the Trim limit switch replacements.
All of which are on my "to-Do" list.
By the way, this is a boat my wife picked out as "Her" boat. So, I am trying to make sure it is a safe as possible.
This boat can be a scary ride when at top throttle. And my wife can be scary if she thinks "Her" boat has a problem.
So, I am plunging ahead with this repair to "Her" boat.
