Idle screw location on 9.9?
howie70
I may be blind but I can't locate the idle screw on my engine. About a 1994 model Evinrude 9.9. I know where it should be according to the shop manual but I don't see it.
Hopefully my pics load. On the first pic from top view the screw on top is can follower adjustment? Looks like idle screw should be kind of behind that? There is a hole but no screw in it.
The screw on left is slow speed mixture screw?
Vic.S
The screw with the spring under its head . (LHS in first pic, foreground in second pic) is the idle mixture adjust. #15 in the parts diagram.
Dont mess with the cam follower adjusting screw... very easy to break the plastic part. its screwed through
convert
AlTn
are you trying to set the idle mixture or the idle speed?..or both?..is this a tiller handle or remote operation?
