Idle screw ajustement in neutral or in gear
pecheux
Hi y'awl, I read different version sooooo .... let me ask you. On my Force 15hp, should the idle speed be ajusted while the engine is on idle or in gear ? And what is the proper procedure for the idle screw setting ?
Tx
eurolarva
Re: Idle screw ajustement in neutral or in gear
In gear with motor warmed up and as low as possible RPMs that motor will run without dying.
Turn clockwise in 1/8 turn incriments till motor starts to race. Then go the other way till motor starts to stumble. Find the half way point between these two areas and that is where you should be. When making your adjustments wait about 20 seconds between each move.
pecheux
Eurolarva: thank you, will try just that.
one more thing .. when I turn clockwise and the rpm increases (races) it ususaly end up stalling after 10 to 15 seconds with the idle screw in that position.
When you mention turning clockwise do I presume you mean as long as the motor keeps running ?
tx
pecheux
Eurolarva: did it just as you said = idles great at very low rpm now.
Thank you.
Have another problem but will need to open a new post.
