The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
Remember: If you change the prop to a different pitch, the load in gear will also change and the idle speed will most probably need to be adjusted. I have a 125 with a 19 pitch prop. In order to get 700 RPM in forward, the neutral RPM is up around 1,000. With a 17 pitch prop, neutral RPM is about 900.
