I have a 1978 235hp evinrude . I can't for the life of me get the idle to come down. It all started when i changed the plugs. I retarded the timing as far as it would go back performed sync and link did everything. The best i could get the idle to go down to was 1100rpm in neutral motor is in the water. The power pack went out on one side put on a new one and now the idle won't go below 1800 rpm. I finally gave up and called a mechanic he told me there is a vacume leak somewhere. I changed all the gaskets related to the carbs no help . The mechanic came over and said the manifold gasket was leaking he put a new one no help. He said he talked to a rep from evinrude and said the problem was in the power pack even though the serial numbers is a correct replacement they are color coded and both packs have to match or it could result in a high idle. Any help would be appreciated thanks.
