DukesFin
- Oct 12, 2005
- 502
GM L6 250 cid, stringer electric shift outdrive, holley 3160 390cfm carb (Carb is brand new)...
Okay, got the carb on and engine timed. Book calls for an idle speed of 500 - 600 rpm. I have the idle dialed in at 600.
When I put the boat in gear, (just barely move the throttle enough to engage the outdrive), it dies, feeling and sounding like it is not getting enough fuel.
You would think to adjust the idle speed up to solve the problem, but I don't want to hear the "clunk" of the outdrive engaging get any louder (not that it is so loud it's a problem). I'd imagine I'd have to adjust it up to 800 to 1K rpm to solve the problem this way and I'm sure it would not take long to damage the lower unit by having it engage the gears at such a high rpm setting.
So, not wanting to damage the motor that has about 75 hours on it, I thought I'd run an idea of a solution and ask the question here...
Should I try adjusting the idle mixture screws or is there something I'm not doing right? There is NO smell of fuel and NO smoke at all when I'm in neutral, idling at the dock. I have not messed with the idle mixture screws from where they were set by Holley.
Right now, other than the problem mentioned above, the motor runs great and sounds AWESOME and I'd like it to be perfect.
