bill and doris
- Mar 7, 2009
- 48
I own a 25ft Voyager tri/ctr console with a 115 4cycle merc. I have recently started fishing alone or with my wife. I tend to tie up under overpasses which makes for interesting rope and boat handling all at the same time. The layout of the boat does not lend itself to a trolling motor being mounted in the front, since I tend to trip over everything It would be easier to maneuver the boat at idle if I had a way to kick the rear of the boat one way or the other. the boat has 1 bracket on each outboard toon where the 2 depth finders Voyager uses are mounted. I thought if I mounted a small thruster on one that might do the job, but I can't find anything. Now I'm leaning toward 2 large bilge pumps mounted in the ctr toon plumbed to each toon with the flow going to the side with one switch controlling one or the other. There may be an easier way to do this, but I just havn't figured it out. I thought I would see what ideas might be out there.
