Scubaslife
- Oct 29, 2012
- 25
I rebuilt the power head on my 94 Johnson 112 SPL and I'm having trouble getting it to idle properly. It will run out well and cruise well but won't hold idle more than 1 or 2 seconds. However, if I tilt the motor up it will idle for about 30 seconds but eventually die. I took apart the carburetors and cleaned them VERY thoroughly with Seafoam carb cleaner but I didn't rebuild them. Beginning to think I need to order a carb kit and rebuild them but didn't want to do it if there's another easier explanation that I've missed. Any thoughts?
Things I've already done...
Replaced check valves
Replaced primer ball
Replaced fuel pump
Replaced plugs
Replaced plug wires
Cleaned carbs (but didn't rebuild)
Thanks
Scuba
Replaced fuel pump
Replaced plugs
Replaced plug wires
Thanks
Scuba
