Idle issue 1990 Yamaha
privateer90
I have an idle issue with my 115 yahama. I have adjusted carbs once, but still will not idle. Seemed to idle fine for a little while, then went back to cutting off. When the motor is running it runs great. Any ideas??
99yam40
Re: Idle issue 1990 Yamaha
You should not have to adjust the carbs unless there is some problems happening to your motor like passages plugging.
Sounds like it is time to pull and clean them and then do the link and sync properly like the service manual states
