I just bought tohatsu 9.8 2-stroke, short shaft that is probably from around 2003. It is immaculate and was used only in fresh water. When running, I get strong water flow out of the check port but water barely spits out of the idle hole. If I remember correctly, my last Tohatsu 8, which is virtually identical threw a steady stream from the idle hole. I flushed the 9.8 with muffs for 10-15 minutes and tried to clear any blockage with 1/8" monofilament line but had no luck.<br /><br />Can someone confirm/correct my belief that I should get more than a light spitting of h2o from this hole and also let me know how I might clear a blockage?<br /><br />Thanks!
