Hi,
my motor is Tohatsu 18MFS. Idle is fine after start, but occasionally after high rpm load it 'freezes' a bit higher lever. Then, the gearstick is hard to push on reverse and when pushing back from reverse to forward (easier), stick moves but gear doesn't shift to forward (or neutral) until throttling more. Is there some limiter for shifting gear in higher rpm? Recently changed sparks and adjusted idlescrew and rod connected to carb to get it work on low rpm. Where to start with this new problem??
