I have a 1970 Ebitide tri-hull with a 70 hp chrysler outboard on it. I was wondering how to adjust the ide on the carbs ... if I start it in nuetral and then throttle back to put it in gear it will die so I start it in gear with the throttle half "up" (is that the correct term)... I also seem to have to file the points every other time I go out and the spark plugs tend to be covered with oil .... I know they burn mix gas but don't know if this is normal. Could this have something to do with the idle?
