idle adjustment on a bf15
digimortal777
I have a brand new 04 honda bf15<br /><br />its a gereat motor my only gripe is that it trolls a bit too fast when im pike fishing....<br /><br />is there a throttle stop screw anywhere on this engine , i dont want to go messing with the idle mixture , my old johnson 15 had a adjuster on the side of the engine
stanstv
Re: idle adjustment on a bf15
if you find the answer let me know as i have a 04/20hp --- i also have start up, choke/fast idle problems, is your transition from choke, fast idle, to idle correct and smooth without any stall etc/
digimortal777
i pull the choke fully and pull the rope she starts smoothly and as i push the choke in it settles nicly<br /><br />but itf im tryin to troll for pike its too fast , the lures just dont work the way there meant too<br />if im catchin trout then its fine.....
stanstv
mine is electric start, w/electric choke - different ball game. thank you
jim dozier
This is why they publish manuals. You can have years of experience and a masters in mechanical engineering but unless you have seen this particular engine you won't be able to tell someone exactly how to adjust the idle linkages and mixture. Go to the bottom of this web page an buy a manual for your engine. You need one. Everybody needs one (for their engine). It should be the first thing you buy after you buy the engine. It will tell you how to adjust it and if you feel inadequate for the task it will at least make you sound like you are informed about your engine when you ask a mechanic to do it for you.
45_red
Better yet, get the shop manual first;especially if you are buying used.
stanstv
idle must be set at 900rpm +/- 50, in neutral,engine at normal operating temp for it to function properly - just went through it with my dealer - now am dragging a bucket to slow down.
hondon
You might consider getting some fatter buddies.
bbutturff
Another solution would be to get a prop with less pitch. It'll probably cost you about $80 but it'll do the trick. Just a thought.<br /><br />Bruce
gss036
I would think maybe, some still makes a troll plate the will bolt on and flip down behind the prop to help slow you down. It would be a greast investment if you need the slower dpprd often. I did that years ago on my 1976/ 9.9 2 stroke evinrude, in fact I still have it and the motor.
radsrh
Overton's still has the drop down plates.
bbutturff
I changed from a 9.5 pitch prop to an 8.5 pitch prop on my Nissan 18 hp 4-stroke and GAINED top end because the engine wasn't turning the rated RPM's at WOT in the first place. In addition, I can now troll the motor down to less than 1 mph when I pike fish. The prop cost me about $80 and was well worth the investment. Plus, now I have a spare prop for insurance.<br /><br />Bruce
