freeisforme
- Mar 23, 2009
- 184
I came across a half dozen old Eska and Sears outboards this week.
two of them run, both that run have no prop. The others either lack spark or just won't fire. No two are identical. Most appear to be early 70's or older.
Most have been repainted, several were most likely in use just prior to storage as four were still clamped onto small boats. They were put up in a barn, of which I purchased all the boating items at auction.
The list is as follows,
1- 7.5hp Ted Williams (Has points ignition).
1- 7.5hp Gamefisher (Same as Ted Williams but with fuel tank under the cover. No points, some sort of electronic ignition).
2- Sears 5hp different years, one with huge tank and shroud, the other with a small tank on top and tin skirting around the power head.
1- Sears 3hp, this was marked 'New 4-16-1973' in white paint on the side
1- unknown Eska, similar power head to the Sears 3hp but with a larger lower unit and different tin work. Its painted over in olive drab and black paint.
The Gamefisher 7.5 is seized, it appears stuck somewhere down low, as I can move the motor a bit, but the prop is locked up solid. My thought here is that this one will donate it's shroud or fuel tank to the Ted Williams 7.5hp.
I don't really have a use for these but would like to get one of the 5hp motors, and one 7.5hp running just to have. The others are most likely going to donate parts for the others.
The two that run, both 5hp models.
I read through a lot of former posts but am unclear on whether these have water pumps or are 100% air cooled. If they are partly water cooled, where is the pump impeller and how do I get at it?
Second, do these have any sort of clutch or are they in gear all the time?
What sort of seals need to be checked to be sure these are water ready?
