alesserfate
- May 27, 2009
- 37
I need to replace this upper rubber exhaust bellows, it connects the riser to the outdrive inside the boat. Engine is Mercruiser 470 outdrive is Alpha One.
This is the bad bellows:
The upper I/D is about 8cm, the lower I/d is about 6.5-7cm.
This is the riser on my motor:
So far the only things close I found are the following, none say they are for my motor:
https://bpi.ebasicpower.com/pc/GLM89060/MER9D
Exhaust Elbow Bellow for Mercruiser 140 & 165 GM Engines. This item replaces 53114A1.
and
https://bpi.ebasicpower.com/pc/MER45597A1/MER9D
Exhaust Bellows, Mercruiser 120, 160 HP Inline Engines
I need to order a part but can't find a matching one, if anyone knows exactly what part I need would be a great help.
and
