iboats shop side broken
trying to buy things....... search function broken [h=1]There has been an error processing your request[/h]
Exception printing is disabled by default for security reasons.
Error log record number: 501199115547
off to ebay.
jbcurt00
Thanks for the heads up, notified Admin.
Apoligize for inconvenience, hope ya find the parts you need
still broken. cant pick the paint/maintenance from the icons or menu [h=1]There has been an error processing your request[/h]
Error log record number: 1086486329615
southkogs
Been monkeying with a couple of searches on my lunch break, and I'm getting the same thing still. I'll pull the "hey, fix this!" lever again. :lever:
retail side search is still broken
got this looking for bimini top hardware. [h=1]There has been an error processing your request[/h]
Error log record number: 887054032601
Kiter007
iboats.com employee
Scott Danforth GA_Boater experienced the same problem. I tried to reproduce it, but I couldn't. Curious, have you cleared/deleted your browser's cache (including old Javascript)? Please let me know whether that works AND/OR what I can do to try and reproduce the error.
Kiter007 since I jump from machine to machine, when the problem surfaces again, I will let you know. however it happens when using the search for something on the retail side.
also, you may want to review the search function. for example, a search for bimini slide jaw only brings up the nylon slide jaw fittings, and doesnt bring up the stainless fittings. that could be a key word clerical issue
a search for moeller zinc primer used to bring up a moeller primer bulb this morning I get "Your search returned no results."
by the way, it looks like iBoats no longer carries the moeller zinc dichromate primer, yet they carry the top coat colors.
