swaycleveland
- Mar 28, 2010
- 91
facts
1985 4winns santara 217 fisherman
22 ft
4000lbs ?? guessing
3.8 l v6 producing a whopping 185hp 300 hours
perfectly tuned ( i'm so anal about this)
rpm range 4200- 4600 max
omc stringer
final gear ratio 1.71
current prop 14.5 x 19 stainless unknown brand original
bottom smooth as a baby's bottom
prop condition very nice
hull is not water logged
Bennett trim tabs
now that I've given you the skinny on the boat here's what i'm looking for. I now have a convertible top on it ( canvass attached to the windshield and going back only 5 ft) I have now lost some speed and rpms due to the drag from the new top. Previously i was right where you'd like to be as far as rpms, whole shot and top speed were concerned. she would spin up nice and i could reach 4600 and somewhere around 38 mph (gps) depending on the conditions. I now come in with an average of 4300 rpms and 35 mph. Not really a big deal but i have noticed that mid range is a bit lower then i would like I generally cruise to fishing spots and to and from the slip at about 3000 rpms and run about 23 mph.
I would like a new prop to use regularly and use the old as a spare. the new prop i would like to be a aluminum prop. 4 blades
I picked this combo because i would like to cruise at 2800 while maintaining the 23 mph. To achieve this i'm thinking something like a solas brand 4 blade in the 15 or 17 pitch I'm leaning toward the 15 for many reasons. The general rule of stainless to aluminium ( rpm lose) and the 3 blade to 4 blade ( rpm lose) and the fact i'm down a touch on my max rpm specs.
I dont run up at the higher rpms and speed but the extra power would come in handy on lake Erie to over come rolling waves and heavier loads
if you all wouldn't mind weighting in on 15 or 17 or anything else you'd like to add
thanks
22 ft
4000lbs ?? guessing
omc stringer
Bennett trim tabs
thanks
