I want to add power tilt/trim to my 72 Johnson 65ESL72 outboard
I want to add a power tilt/trim to my 1972 65hp Johnson 65ESL72 outboard. Can the tilt unit from a 1972 Johnson 125hp 125ESL72R be adapted to work with my motor? Thanks in advance for your advice.
F_R
Correct me if I'm wrong, but I don't think they offered a power tilt & trim in 1972. Power tilt only. And the 65 / 125 were different.
oldboat1
Sort of a standard suggestion here is to consider an aftermarket t. and t. unit. They are expensive, but so is a working original equipment version, if available for your motor and if you can locate a unit.
jimmbo
CMC is about the only way to get power trim on a pre 73 Evinrude/Johnson outboard
Find a newer 70 HP midsection with trim/tilt.-------Install your powerhead and lower unit ??-----Never had to do one but might be possible.
