Hey guys,
New to the forum and to marine mechanics I am deterred to get to the bottom of my boats problem lol I have a 1996 sunbird 170 fish and ski with a V4 88hp Johnson 2 stroke, the problem im having with the boat starting consistently. I think its the neutral safety switch bc i have to pull forward and backward on the throttle to get it to start. If i keep it in neutral and pull back the boat will throw the starter every time but once i push the bottom in to engage in fast idler to give it gas the starter stops. With a little patience i can always get the boat started i.e.. rip throttle back a and forth to get it started. Once in a while the boat will start in gear and take off on me, Also a few times i would put it in gear and the boat would run in revers. I would have to shout it off and shake it to get it to mover forward.
Where is the neutral safety switch on my motor or throttle, and if it is in the throttle linkage how do you adjust it. I can hardly fit my hand in their i don't see an easy way to get to the switch.
I would appreciate any help guys
If you need more info just ask
Oh PS. might be unrelated but a few times i would have the boat open at around 4000 rpms and it will just bog down and die on me. After restarting the boat it response normal and no indications if any problems
