I think I'm screwed.. 95' 5.7 Merc
cwmtb1
I have a 1995 Chaparral 2135 with a 5.7 Merc. I think I'm finding out the hard way that I didn't winterize like I should. I started up the engine last week and seamed to run fine. I looked in the engine compartment and saw water leaking from both the right and left exhaust manifolds. I removed the engine cover and saw that both exhaust manifolds have cracks. I replaced them (new gaskets for risers and manifold) and THEN checked my oil.... Yikes, major milk shake mixture... I took the old exhaust manifolds and poured water into the riser ports to see if it would leak through into the exhaust ports... nothing. <br /><br />I changed the oil twice and it still looks white. After I pumped all the oil out the second time, I could here something leaking inside the motor. I waited about five minutes, then pumped some more, and out comes water..... A compression check shows all cylinders at 150+. Is there anything else I can check before writing this off as extreme stupidity and replace the block?
tashasdaddy
Re: I think I'm screwed.. 95' 5.7 Merc
could it be a cracked intake manifold leaking into the block? mine had a tendency to hold water in the cooling passages.
Haut Medoc
Pressure test the cooling system, to try and isolate the leak.....<br />It does sound like you have cracked the block though :( .....JK<br />Welcome to iboats, BTW :)
My Guess is you'll Find the Answer Under the Intake Manifold............<br /><br />Probably the Block,.... At the rear of the Lifter Valley.........<br /><br />I Think the Title of your thread pretty well sums up Your predicament...........Sorry........ :( <br /><br />Welcome to the forums here at iboats,......<br />If You're Capable,..... We'll walk ya Thru it.......... ;)
cwmtb1
Well I just took off my intake manifold and low and behold.... crack in the block. Doesn't take a big crack to get a bunch a water in your oil... I'll add a link to view some pics shortly.....
Boomyal
Sorry to hear CW. Been there and done that. :mad:
cwmtb1
Hers a pic of the crack..
