patrickray
- Feb 15, 2008
- 256
I hope no one gets offended, but I see this everyday here...
Quote "I just took my carb off from over the winter and cleaned and replaced the gaskets" by (mpboatr)
Answer "Remove the carburetor once again and clean that jet thoroughly" by (Joe Reeves)
That being said, maybe there could be a FAQ if you cant run at WOT, idle, in gear, etc....
I learned from here that when you work on the carb. Get a small piece of wire and make sure the jets are cleaned out good. Soaking dont do the trick. Then you dont have to do it again.
Thanks everyone
Patrick
Thanks everyone
Patrick
