AttheDocktors
- May 22, 2008
- 12
Before I bombard everyone with my battery question or questions, I promise that I have scoured the forums for an answer to my scenario and have not found one. If it?s out there please feel free to share the link. So here?s another battery question. Sorry so lengthy, wanted you to understand what I'm doing...or not:
I have two Interstate 24M RD cranking batteries on my boat. The last time the batteries were on a charger was about 2 ? months ago. The last time I powered up the boat was a month ago ? with no problems - when I had it serviced for the season. I wanted to get it ready to take it out next week so last night I decided to connect my Schumacher Ship 'N Shore battery charger SSC-1500A - 15/10/2 amp selector to one of the batteries to start charging them. When I make the connection, the ?connected? led light does not come on indicating that it is connected, nor does the ?charging? light come on. I connected the battery charger to my car to ensure that it was not faulty and the ?connected? and ?charging? lights came on. I also tested the boat?s batteries with a digital volt meter and one did not read at all and the other initially read at 100% when touched but then starts to rapidly drop its reading to 0. I tested the volt meter on my car to ensure that the meter was also working and it did. I researched the Schumacher site and found that the automatic charger needs to ?see? at least 4 volts in the battery to power up the circuitry. This initializes the charge sequence. When a completely discharged battery, or one with less than 4 volts charge remaining, is attached to the charger, the charger never ?sees? this battery and will not begin the charging cycle. It will also cancel out the Engine Start function. The yellow charging light will also not come on.
The next thing I did was connected my Vector Emergency Portable Power Station to Battery 2 and set the switch to that battery. I waited about 5 minutes then tried to work the bilge pumps. Nothing. I turned on the bilge pump switch and also tried to manually empty the water triggering the bilge float. Nothing happened. I turned on the blowers and nothing. I thought the bilge pumps and blowers should be able to come on without starting the boat?.especially for safety reasons. I might be missing something here when using the Vector.
So my questions are:
1. Would it be best if I hooked up my shore power line (I have the adapter that hooks up to a regular outlet) and set battery switch to both? Maybe this will help trickle some juice in the batteries then I can hook up the battery charger?
2. Is there anything I can do to charge up these batteries or are my batteries shot and I need to replace them?
