I picked up the engine today,feeling very good
a1machinista1
Steve the P.O. called me this morning and said he dug it all out, SO I think I ended up with a very workable situatuion.. First off the good, He had bought a good amount of gaskets the day he tore the motor down, also had new 90 oil for the lower end, and new bearings and seals for the engine
A very nice bonus was that steve is a very smart cookie, hes a very old navy man, He labels everything!! I use this most of the time , when I do odd jobs, so thank you sir.. 90% of the pieces are marked like this, A little hard to make out what was written on tape, But I think i can get it
So Its a 1991 90 hp force (havent verified the 90hp yet) bayliner with the L drive, This is the unit that steve was most woried about!! It was under water for about 6 weeks back in 1996, he drained the boat, pulled the electronics, and tore the power head apart, they installed the crank and rods/pistons back in before he stored it, Im going to pull it apart since it was in storage for 12 years and since I have the gaskets... anyway he said he thought the hole piece needed replaced because he thought it wouldnt be any good (6 weeks under water,but im sure in not going to find a new one, and Im real sure im not going to find a used on that looks this good.. SO can I still get the reset buttons??? The power strip shouldnt be an issue to find, I peeled back a bit on one of the red wires to see what the core of the wires looked like and ive seen worse!!! Have any opinions????
He also bought a new prop which was cool because the old one have a little corrosion in the thrust end.. The new one is on the left he didnt wrap it
So evry thing is here ( I believe) should i put a different set of reeds in ?????
IF SO?? what type or brand????? im clueless, Has anyone been through this process a few times???????? I feel very comfortable doing this but it never hurts to have an extra mind available!!!! AND how do I figure out what size the engine is??? I was hoping it would be on top of the spark arrester but no dice!!!!
a1machinista1
Re: I picked up the engine today,feeling very good
heres a few more of what I have
I really would appreciate input any off you might have!!! What are some of the things I might not think of? because this is my first venture in the marine catagory!!! I am a automotive machinist and damn good at it!! NO ego at all just confidence!! So please dont think im a *** or something......BUT this is a whole different animal and Im not going to assume that this is going to be a breeze!!!! thanks guys and gals
a1machinista1
Ok heres another thought?? I havent figured out what I can do to this thing to improve performance and since i have the gaskets and a full machine shop available to me!!! How might I improve this engine before I reassemble it??? , I dont have any experiance with adding horsepower and or torque to a two stroke. So any proven upgrade ideas would be great..
kandil
Since you have all the parts and a long winter coming you ave got nothing to loose just get a good shop manual for this outboard and go to work most likely you are going to need some electronic replaced but the metal parts should be OK it looks like he cleaned every thing very good
PS I have 90HP head with low comparison in Cly 1 from a 1994 that I toke out and it has many parts that are new I don't know if they are the same PM me for the parts that you might need.
a1machinista1
I also have a force manual that came with it!!! And that is great about the parts you may have. Hopefully I wont need any. thanks!!! so have you heard anything I might research to improve the two stroke?? I figure since ill have it apart, and access to a full machine shop I should invest a little time in improving the engine... New reeds??? what type or brand??? match port??? raise compression??? diff plugs?? indexing plugs???? anything???
