I/O owners...... motor UP or DOWN when in your slip ??
Status
Not open for further replies.
Thajeffski
Master Chief Petty Officer
Well ? What do you do?
Every I/O at my dock is up. Doesn't make sense to me as only 1/8th of the motor is actually out of the water......
shout
Re: I/O owners...... motor UP or DOWN when in your slip ??
I've been told/read that leaving the I/O up is hard on the bellows etc. I've tried both ways, currently leaving the I/O down because I'm worried about a leak.
- Shout
bruceb58
Leave it down...always. Unless there is something you aren't telling us like low tides!
Rscardina
good point about the bellow..it is extended when up but i would think it doesnt really matter much, except... the anode fin is not in the water..and with the water movement i would think your prop and other thing may be in danger of wearing due to electrolosis.. I dont know.. the anodes on the transom and the fin make a triangle field of protection..so maybe it is best to keep down so the anodes do what they are designed to do...just my guess
ewenm
i keep mine (2) down, dont want the trim rams exposed same with trim tabs, all the way up
again dont want the rams exposed
DBreskin
If there's no chance of hitting bottom, the unit should be down. Leaving the unit down allows the drive bellows to remain in it's natural, relaxed position, without any stress. If left up, the bottom of the bellows is stretched which lessens the life of the bellows and increases the chance of failure (and sinking).
As stated above, leaving the unit down also retracts the trim rams, protecting them from exposure.
RichRab
I agree on leaving it down to save the bellows. Very hard to change.
smarks
Your talking about when the boat is in the water.. leave the the stern drive down.
What about on the trailor? If I leave mine down on the trailor it will hit the ground unless I tilt the trailor way down in front and then the boat collects rain water. I'm kinda stuck
Steve
This_lil_fishy
Steve
I trim mine down as much as possible once parked on the trailer. Obviously you can't get it all the way down, but I put a block of wood down and lower it down until it touches..once I got the bow up where I want it..this also prevents water getting trapped and freezing in the early spring/late fall.
Ian
CaliCash
While docked, I leave mine down. While sitting stationary on the trailer, I leave it down....easier on the bellows as others have mentioned.
J. Howard
Yep, I leave mine down nearly all the time. It's definitely down when I'm in the slip.
karatejoe
all the boats here are up. so I followed suit. They are all on lifts.
Status
