Re: I/O opinions vs all others
Adm:<br /><br />There are pros and cons to both systems. IOs are significantly quicker with the same power, they allow you to access shallow water and if you clip a prop you can change it on the spot, and replace it or repair it for a lower cost. The trade off is corrosion, especially in salt water. If you select IOs make sure they have Mercathode systems (If Mercruisers) and new anodes of the correct type. Keep the finish in good shape and they will last, with the exception of certain model years of Bravo III drives which have major corrosion problems.<br /><br />As for V-Drives, the pros are better handling in close quarters and docking and no corrosion issues.<br /><br />Both systems require routine fluid changes and while the V-drives can be serviced without pulling the boat, some drives are quite awkward to work on due to limited access. Major work on a V-drive can be quite expensive since the whole motor and drive must be pulled.
