I need Tohatsu spanner wrench-tilt trim question
ba_50
Hi,<br /><br />I thought I would throw this question out again and see if someone else might have an answer.<br /><br />Is the top seal in the ram guide replaceable by itself?<br /><br />And does the spanner wrench have four pins in it? Are all tilt trim spanner wrenches the same?<br /><br />Does anyone have one that will work on a M50D Tohatsu for sale?<br /><br />How much heat would you apply?<br /><br />Do you use heat and pounding to get the pins out that will allow the tilt/trim to come off?<br /><br />Thank you.
TOHATSU GURU
Re: I need Tohatsu spanner wrench-tilt trim question
Call 972-393-6003. Ask for a tech rep. Then believe what they tell you.
boatingeoff
Im in the same boat i have a 90hp tohatsu that has a leaking trim seal and also looks like i need a four pin tool to remove cap of cylinder. Is this hard to fix once four pin tool is obtained??Would be helpful if someone could post a answer as am not in the U.S.A. Thanks
TOHATSU GURU
You have to buy the tilt piston rod assy. The seal is not designed to be replaced
