Idlespeedonly
- Jun 30, 2011
- 779
First thing I would like to say is this is a great forum, very informative.
I recently purchased a 1989 Ebbtide 224 Catalina Cuddy. I got this boat for 2000 dollars. I feel for the condition this boat is in it is well worth it. The original interior is spotless no tears, stains, broken pieces anywhere. I have been in boats less than two years old that werent even close to this one. I bought this boat knowing the outdrive is bad.Apparently it was run with no oil in the upper. The gear fragments have welded themselves into a clump all around the lockring that that holds the vertical gear in. There is no way to disassemble the unit. It even covers the threads in the aluminum housing. As for the lower it is corroded bad enough that it wont come apart. This boat has been in freshwater only. I ran it on the trailer for a little bit it didnt smoke at all once the carb got some gas in it. It has been sitting for about 3 or 4 years in storage.
So I get it home fiddle around with some wiring let it run with water hooked up to the inlet line for about 20 minutes. I shut it off took a look in the oil cap. The oil is very milky. Change it run it for another 20 minutes. Still milky. pulled valve covers off, looks like sombody was hiding their vanilla pudding there. So i pulled the intake of planing to see a big crack, nothing there. so i figured a head is cracked. drain all the water out, rig up a valve and gauge to put some air in the cooling system. I pump it up to 20 pounds. After about 10-15 minutes it is down to around 8 pounds. Deffinately not a fast leak to me. All hoses are tight(not leaking), block drains tight. I know the air is going somewhere. But where? I pretty sure block isnt cracked. I believe it would leak as fast as I could get it in. Kinda sure about heads not cracked. I figure maybe the head gaskets or head bolts.
I know condensation can turn oil. but how many changes to clear it up? That nasty oil has a lot of places to hide. And with no outdrive I cant load it up real well to flush it out. I also know the compression is around 80 pounds on all cylinders. so I know a rebuild is on the to do list. Not worried about the rebuild I have done quite a few. just dont know about the water issue, and cant find a reasonable outdrive for sale. Engine can be rebuilt for around 700-800 dollars i believe. As long as heads and crank are good. So do you think with a rebuild and a new outdrive in the future this boat is still worth the money? Or should I cut my losses and get rid of it.
Sorry about the long post also.
